sodfarmer
Movin on up.
Just a heads up. On Christmas eve my truck developed a soft pedal that truned into no pedal. The problem was a leak in the rubber brake line that goes to the caliper on the passenger side. I inspected the drivers side and it also had rub marks. Worn about 1/3 of the way through. The stock rim rubs the brake line when turned to full lock. Everyone check your lines. I am luck that I was not pulling or going down hill.
Good luck.
Good luck.
