I pulled the engine-trans./transfer case[in one piece] out of my 93 k3500 parts truck today.I split the engine off and put it on the stand to take the heads off. I tried to take the drain plugs out of the sides of the block but no go. I broke 2 -1/4in drive extensions off. Can i heat the block with a torch to loosen plugs? Or is there a better way to remove them? I don't want anti-freeze in the cyl. Also i pulled the glows out and they were wet and smelled kinda like old gas. I had tried to start it before i pulled it but it didn't fire and there was bubbles in the overflow tank after cranking without a belt on.Much to my suprise the engine is a 506 block and it has a goodwrench tranny. Any helpful hints would be appreciated. Thanks in advance. Barry:mad2:
