Anyone know how to get a flywheel off?
doughboy18718
Diesel Retard!
The Burg, VA
I have all the bolts out, but can't seem to get it to budge. Is there anything special i need to do to it to get it off? As much as i want to just muscle it off with a pry bar, i don't want to chance puncturing the oil pan of messing up another vital component.
I'm going to assume you've already done this but I'm going to start with the obvious.
Have you removed the 6 bolts in the center of the flywheel?
If so take a block of wood and put against clutch side of flywheel. Tap with hammer. Rotate flywheel repeat. Keep rotating flywheel.
It sounds like it may have frozen to the end of the crank.
Be careful that it doesn't come off and catch part of you between it and the ground. It is heavy.
Thanks for the help guys!
All it took was some PB Blaster and a little elbow grease (and a BIG pry bar) :reddevil:
