96-2000 GM 6.5 DIESEL FRONT ACCESSORY BRACKETS WITH ACCESSORIES & BOLTS CAN ADD 2ND ALTERNATOR. THIS IS A FULL SETUP OFF A 1999 SUBURBAN, IT INCLUDES ALL BRACKETS AND PARTS TO SWAP TO NEW SYLE SETUP. HAS 100 AMP ALTERNATOR, VACUUM PUMP, BELT TENSIONER, AC COMPRESSOR AND LINES AND POWER STEERING PUMP. CLICK ON THE LINK BELOW TO SEE BRACKET TO ADD A 2ND ALTERNATOR. THIS SETUP CAN BE INSTALLED ON ANY 6.5 OR 6.2 DIESEL ENGINE. JUST THE TWO MAIN BRACKETS ARE $400 ON EBAY, I'M THINKING $450.00 FOR ALL OF THIS, THIS STUFF IS HEAVY SO SHIPPING MAY MAKE IT TOO MUCH TO SHIP.
96-00 6.5L Diesel Dual Alternator Bracket
Designed for use on 96-2000 6.5 diesel serpentine accessory drive systems, this bracket sets the mounting points for a parallel CS130 alternator. This is a direct replacement/upgrade for the long discontinued GM bracket (PN10244209), with a few notable upgrades of my own design: TIG welded...
www.willometmotorandfab.com
