starter wiring problem
thanx for your reply. my starter actualy has 3 wires: 1) wire is the big wire comming from the battery, 2) wire is a fusible link that is connected by a large crimbed connection with 4 other fusable linkwires, 3) wire ,i think, goes to the starter relay and possible other places . When my batters are hooked up the glow plug stays on all the time ; i disconnected the batters and when i went to reconnect then they sparked with lots of fire so i left them unconnected until the next day and tried again they sparked heavy, we heard a faint click, then i connected the batters with no problem. That is when i disconnected the batterys and put this problem on the forum. to cut a long story short, i forgot to plug the warmer up one night and the next morn the GMC would not start, a friend said i needed some starting fluid and he sprayed either into my engin. the engin locked up, tore up the fly wheel, and wrecked my starter. Either might work on heavy equipment and farm tractors but it is a dirty word to me now . At this time the big battery wire and the fusible link wire are connected on the same big bolt at top and the other wire is connecdted to a side little bolt. Can you plezz help me figure where the 3 wires go ?
