Other 6.5 Diesel parts and more
94 k3500 nick
ny long island
SELLING SOME PARTS AND ITEMS BECAUSE OF TOUGH TIMES AND NOT WORKING GOT LAID OFF
*NEED PARTS GONE MAKE REASONABLE OFFERS UNLESS STATED*
NEW PARTS AND ITEMS WILL BE ADDED WHEN I GET A CHANCE TO POST THEM
PM ME FOR PICTURES AND WITH ANY QUESTIONS OR LEAVE UR NUMBER AND I CAN SEND U WHAT U NEED
ALL ITEMS CAN BE SHIPPED BUT A SHIPPING FEE WILL APPLY CONTACT ME FOR SHIPPING INFO
BRAND NEW IN THE BOX DEWALT CORDLESS WET/DRY VACUUM $100
DEWALT XL 20 VOLT BATTERY FOR CORDLESS TOOLS $45
BATTERY MAINTAINERS $5 HAVE 2 THEY ATTACH TO UR BATTERY
12 INCH KICKER SPEAKER CVR 4 OHMS $80 PAID $120 FOR THIS SPEAKER VERY GOOD SPEAKER
BRAND NEW STILL HAS PLASTIC WRAPPING ON IT AMAZON ECHO COMES WITH CHARGER $80
USED CRAFTSMAN METAL CABINET CAN BE HUNG ON WALL $100 ORIGINALLY OVER $300
BRAND NEW IN THE BOX UNIVERSAL HEAVY DUTY PREMIER BRAND RADIATOR
THIS GREAT HEAVY DUTY RADIATOR HAS EVERYTHING EVEN A DRAIN VALVE
CAN BE USED FOR MANY CARS/TRUCKS
SIZE IS
32 1/4 L
18 1/4 H
2 INCHES THICK
$200
BRAND NEW NEVER USED 6.5 DIESEL TURBO INJECTORS ALL 8 FROM SSDIESELSUPPLY $350
6.5 TURBO DIESEL WATER PUMP NOTHING WRONG WITH IT WORKS GREAT $50
6.5 DIESEL RADIATOR NOTHING WRONG WITH IT WORKS AND DOESNT LEAK AT ALL HAD IT AS A SPARE IS CLEANED OUT $100
USED WORKING FUEL FILTER MANAGER GOOD FOR A SPARE,REPLACEMENT OR IF U WANT TO DO THE "FEED THE BEAST" MOD TO IT $100
6.5 TURBO DIESEL CRANKSHAFT PULLEY SUPER LOW MILES AND CLEAN NOT A THING WRONG WITH IT $40
6.5 TURBO DIESEL HARMONIC BALANCER SUPER LOW MILES AND CLEAN NOT A THING WRONG WITH IT $50
6.5 TURBO DIESEL HEAVY DUTY FAN WITH FAN CLUTCH LOW MILES AND CLEAN NOT A THING WRONG WITH IT WORKS GREAT 4 BOLT BOLT ON STYLE $60
CUSTOM MADE MANUAL WASTEGATE ACTUATOR FOR GM TURBOS
MADE IT MYSELF TO CONTROL BOOST LEVELS FOR MORE BOOST WORKS GREAT NO ISSUES WITH IT BOLTS RIGHT UP TO YOUR FACTORY WASTEGATE ACTUATOR LOCATION $40
6.5 TURBO DIESEL STOCK/OEM CROSS OVER PIPE NOTHING WRONG WITH IT HAD IT AS A SPARE IN CASE MINE LEAKED BUT NEVER DID $50
6.5 TURBO DIESEL AC DELCO BELT TENSIONER WITH MOUNTING BOLT NOTHING WRONG WITH IT HAD IT AS A SPARE DONT NEED IT ANYMORE MIGHT FIT OTHER TRUCKS OR CARS TOO $20
6.5 TURBO DIESEL VACUUM PUMP WITH PULLEY CAME OFF MY 94 TURBO DIESEL WORKS FINE $80 FOR BOTH THESE GO FOR OVER $200 FOR BOTH NEW
88-98 CHEVY SILVERADO C/K SERIES GOOD INTACT HOOD STILL HAS UNDER HOOD INSTALLATION ON IT AND IT STILL HAS TURBO DIESEL DECALS ON THE HOOD TOO $100
BRAND NEW CHROME 16 INCH 10 BOLT RIM
I BELEAVE ITS EITHER UNIVERSAL OR FOR A VAN OR TRUCK I CANT REMEMBER
SIZES R
10 BOLT HOLES
U HAVE 5 INCHES OF BACK SPACING OF THE RIM TO THE EDGE OF THE LIP IN THE BACK OF IT OR SIDE TO SIDE
13 INCHES FROM THE INNER LIP OF THE RIM TO OTHER LIP
TURBONETICS 7868 HURRICANE BENITA TURBO
TURBO HAS 1000 MILES ON IT
ITS A GREAT TURBO WATER AND OIL COOLED,NO LAG, AND SPOOLS QUICKLY AND CAN MAKE GREAT POWER
I PAID $1500 PLUS SHIPPING FROM TURBONETICS DIRECTLY
WANT $900 SINCE ITS BASICALLY NEW AND HAS NO MILES
Hurricane 7868 Benita
78mm compressor matted to a 68mm turbine wheel
Turbine Housing Inlet / Outlet
4.0" / 2.5"
T4 0.96 A/R 3" V-Band
MORE INFO ON IT ON THE LINK BELOW
https://turboneticsinc.com/store/ind...&product_id=84
PRECISION 6758 TURBO WITH NEW HARDWARE
CAME FROM COMPANY CALLED PERFORMANCE AUTOWERKS AND IS THEIR TOP OF THE LINE TURBO WR-3
WAS GOING TO USE IT ON MY COBALT SS BUT NEVER HAD THE CHANCE TO
ITS PWERKS PROTOTYPE TURBO THAT THEY USED FOR A SHORT TIME, THEY DONT SELL THIS ONE ANYMORE
GREAT TURBO FOR ANY 4 CYLINDER OR 6 CYLINDER
BOUGHT IT FROM A MEMBER ON THE COBALT FOURM AND HE HAD IT LOOKED OVER BY PWERKS THEMSELVES HAVE PAPER WORK
WAS TOLD AND SHOWN THIS TURBO EASILY MADE 500+ ON 93 PUMP GAS
ALL NEW HARDWARE AND PARTS WERE PURCHASED BY PWERKS AS WELL
AGAIN GREAT TURBO FOR THE $
EASY 500+ TO THE WHEELS AND MORE WITH THIS TURBO
PAID OVER $2000 FOR EVERYTHING HERE
I WANT $1600 FOR EVERYTHING
MORE INFO LINK BELOW
http://www.performanceautowerks.com/...upgrade-p-1952
BRAND NEW NEVER USED PELICAN ELITE COOLER
WHITE IN COLOR
SUPER HEAVY DUTY COOLER
NEW NEVER USED STILL HAS ALL TAGS ON IT
45 QUART SIZE
$300 FIRM
I PAID MORE THAN $450 FOR THIS
Up to 10 days ice retention, freezer grade gasket, 2" polyurethane insulation
Dimension: INTERIOR (L X W X D) 19.00" x 12.00" x 12.00"
Dual Handle System (Molded-in & Hinged Handles)
Press & Pull Latches (Wide for Gloved Use)
Molded-In Tie Downs. Guaranteed for Life
Technical Details
Color WHITE
Item Dimensions 21 x 20 x 30 inches
Item Weight 35.95 pounds
Shipping Weight 39.85 pounds
Size 45QT
I ALSO HAVE PARTS FOR COBALTS,CAVALIERS,CAMARO, S10 PICKUP, 01-05 CIVIC LET ME KNOW IF IN NEED OF ANY PARTS FROM THOSE CARS TOO
Is the vac 20 volt? What is the AH on the 20V battery?
Do they have the red and green lights?
SIZE IS
32 1/4 L
18 1/4 H
2 INCHES THICK
$200
SIZES R
10 BOLT HOLES
4.0" / 2.5"
WHITE IN COLOR
45 QUART SIZE
$300 FIRM
Technical Details
Color WHITE
Size 45QT
DEWALT TOOLS SOLD
HAVE ONE SMALL 20 VOLT XR BATTERY LEFT $35 NEW
SIZE IS
32 1/4 L
18 1/4 H
2 INCHES THICK
$200
SIZES R
10 BOLT HOLES
4.0" / 2.5"
WHITE IN COLOR
45 QUART SIZE
$300 FIRM
Technical Details
Color WHITE
Size 45QT
