6.2 CUCV drains bats
DEERE3594
I welcome everyone...not just Penguins!
NE Ohio
Buddy has a 80's CUCV 6.2 blazer that drains the batteries over night. He has tried 2 different sets of batteries with no luck. I dont know anything about the 24 volts and he is by no means a mechanic. He said he heard the alternators need to be synchronized? any ideas? :smile5:
AFAIK each Batt has it's own alt. One Alt is grounded the other is isolated. I believe the 24v is kicked down via the resistor on the firewall. I assume he tried disconnecting the Batts overnight ?
Time to try a parasitic load test it sounds like. Here's instructions for a 12 volt system. Not sure if it's different for a 24 volt system.
http://ww2.justanswer.com/uploads/JHoop/2009-08-24_141346_Parasitic_draw_test.pdf
It's quite simple with access to a Digital Multimeter that has a 10 amp setting. Typical draw should be about 500mA with everything off and the key in the OFF position. Also make sure the dome lights are off, as you will get a false amp draw reading with them on.
Thats what he has to do every night...
thanks for the replys, its not his daily driver so Im slowing trying to figure this out :thumbsup:
one alt is just an old school caddy 100 amp alt IIRC it's the D/S one. The pass side is an isolated alt(I may have that backwards) but as Davo said that is a strong possiblity.
