Sandracer799
Recruit
The 4L80E I swapped into my '87 k5 started acting like the converter was going bad the other day. Like it was slipping. But upon further diagnoses it is not the converter. When you put the truck in first the truck goes great shifts through all the gears. When you put the truck in second, it will start out in 2nd like it is suppost to. (Aftermarket tranny controller from TCI)
However when I put the truck in OD the truck will sometimes start out in 2nd and sometimes start out in first. And if you give it half throttle or more the tranny doesnt know what to do and starts shifting back and forth violently causing the whole truck to shake.
i have replaced both shift solenoids and it is still doing the same.
Also I know there is an actuater screen in the valve body. Could this be clogged, causing incorrect line pressure to the solenoids?
My trans guy doesnt think it is anything major to where it would need to be rebuilt. Also I talked with the TCI tech department and he told me that some mechanics have a "Zoom Box" that by passes the computer to see if the trans if working correctly. Anyone heard of that?
Anyone have any ideas? I am ready to blow the damn thing up.
