jmack91z28
Jason
I've got a 93 model 4L80e 2wd and I'm going to adapt it to 4wd.
This tail housing: Extension Housing, 4L80E 4x4 (2 5/8" Long) Aluminum (Cast # 15724251) https://www.wittrans.com/SchematicParts.aspx?Transmission=4L80E&LinkCode=770
This output shaft: Output Shaft, 4L80E 4x4 (5" Long)(With Lube Hole) 1991-96 https://www.wittrans.com/SchematicParts.aspx?Transmission=4L80E&LinkCode=678
I talked to a guy at advanced adapters and he said that should be all I'd need to adapt the 4L80e to my np241 transfer that's in an 89' model V2500 Suburban.
Does all this make sense to ya'll? Anything I'm missing? The transfer case has a VSS in it so I shouldn't need the reluctor in the output shaft of the transmission.
I talked to my transmission guy and he said he'd swap everything out for $75. And charge me at cost for any and all misc gaskets and seals he'll need.
