Wondernoob
- Messages
- 1
- Reaction score
- 3
Hi I have a 03 Silverado with a 4l60e transmission and its stuck in 2nd gear in drive and works good when manually shifted. I checked the e pin on the harness and I'm getting battery voltage on pink wire. We replaced the harness in the pan and the solenoids and I even omed out every wire from the plug all the way to the ecm. The T A B C pins on the plug to the transmission I read are grounds so I ran positive battery on a test lite to those pins and on a couple no ground and on some like 8 volts. I was wondering what grounds I should be looking for to replace or clean up. Any help is much obliged. Thanks!
