turbonator
hi guys, has anyone ever used a 3" cross-over? i was thinking of making one, but i think it needs special custom flanges that bolt up to the outlets on the manifolds, what do ya'll think?....
What size are the manifold openings where it bolts up? If they are 2.5 or less, wouldn't 3" be overkill?
I know with my 3" down pipe, the 2.5" cross over barely has clearance on the passenger side anyway. I have to be carefull to ensure the two don't make contact as it is. The fight is the clearance between the cross over, the down pipe and the fender well. I kept hearing a metal clanking noise thinking it was injector lines, injector or worse...nope. Just the two knocking each other around.
Even though you may have choke points, larger pipe could still be advantageous. I dont believe it is in this case, due to the inefficient nature of running all exahust through the passenger manifold and up into the turbo and back out, all sorts of flow resitrictions and inefficiencies. The donut gaskets are choke points even for the 2.25" pipe. With more preturbo volume spooling and holding drive pressures could be impacted.
3 inch pipe also has larger surface area. It's possible that this would cause you to lose some heat energy in the exhaust that would normally be exerted on the turbine wheel.
Or we all start getting center mount turbos with 4" cowl hoods.
Guess its possible you'd have lower EGT's too then![]()
