iamdave0887
Here Comes Chaos.....
hey guys. i'm in need of a starter. the brushes in mine are trashed to the point where one of the brush hold down screws has been worn away by contact w/ the armature. The starter spins fine out of the truck, but god awful in the truck. it seems to have the rotating speed but no power behind it to turn w/ a load on it so it spins fine with no load but it doesn't with a load on it.
I don't know if i can replace the brushes and it'll work a tad longer, or if i should just replace it. I can't afford a starter from a parts store right now. The lowest price i've seen is ~$200. would changing out the brushes help me in this situation or not?
Here's some video of the starter before i cleaned and lubricated the bushings. The slow spin speed is also due to the garbage jumper cables i had to use. with heavier jumper cables it spun about twice as fast.
http://www.youtube.com/watch?v=GlZ4W8fnu6M
http://www.youtube.com/watch?v=PtktFp96n0w
I don't know if i can save it or not guys. what do you think?
