robzombie4551
robzombie4551
Kenny do you have a camping world near you? If not I'll send you a link to a company that sells the membrane. You have to know before you order if you have TPO or EPDM. You should have TPO which will have a fleece backing and is glued to the plywood underneath.
BestMaterials.com is one of the places that will sell you custom lengths.
One of the other options you might want to try is to install bigger S/L that would allow you to cut the bad area out and still retain the factory look.
I know you hate them but if you go to resell it and they know that one should be there it might sway a buyer.
If you only need to go less than 3or 4 in" in diameter to cut out the bad it might be your best option. If you do go this route I'll give you all the PT #s and supplies to get the job done right.
I feel your pain, as I just put a new roof on my unit back in june. Pm me if there is anything I can do to help you figure this mess out. Or just call me at 413-433-0533.
