2000 C/K cabin fan-only works on High
GM Guy
Manual Trans. 2WD Enthusiast
NW Kansas and SC Idaho
What all needs replaced/fixed when a C/K cooling fan only works on high?
This is on a 2000 OBS C3500 with air conditioning, so it is the fully electric panel.
Resistor unit under dash on blower motor I believe. Look on DP for the threads. Its a $25 part at parts store.
might be behind the glove box... I think it is on my interior style...
may be the windows 98....or the DP site....or my cruddy luck with the search function...but i did not get anywhere on DP. Would someone mind posting the link?
Thanks
Ps, this is what i got:
Diesel Place Message
The search term you specified (on) is under the minimum word length (3) and therefore will not be found. Please make this term longer.
If this term contains a wildcard, please make this term more specific.
as much as I hate to say it... try using the google search on that site... Ive I knew the answer off hand i would tell you.. wish I did
ask turbine doc he said something about that subject in north maines thread parting out his truck when he was asked about the heater controls
ask turbine doc he knows
