2000 Burb sticky door handle
ak diesel driver
6.5 driver
alaska
Got tired of the handles sticking on my wife's burn. The issue as you can see from the pics is rusty pivot pins. Couldn't drive them out so I ground off the ends with my dremel and then drilled them. The drilling proceeds heated the plastic to the melting point. This was good as it freed the rust/plastic bond, just be careful not to melt it too much. As soon a I saw plastic starting to bulge out I'd stop. Once the hole was drilled they punch out relatively easy. I used a deep socket behind the pin so I didn't break the plastic.
Oh yeah after the pin was out I drilled the plastic hole out to just over 3/16" and used a SS 10-24 pan head machine screw with a SS lock nut.
