GM Guy
Manual Trans. 2WD Enthusiast
Well the slave cyl gave out on dad's 1998 GMC C3500 Chassis, 5.7L Vortec, 5spd, 2wd.
i had a few questions:
1: What special tools are needed (dad is geared up to work on the IHCs, not :Chevy_anim: no clue what is needed :hand we already know about the line disconnect tool, Kent Moore J 36221. Are there any others?
2: What source is reccomended for the replacement slave cyl?
GM dealer quoted about 200 bucks, GMPD is about 134 including fees.
3: can i use hydrauilc fluid instead of brake fluid? or if i can only use brake fluid, would synthetic fluid prolong life?
4: what is the best way to bleed this?
Any input greatly appreciated, thanks!
