1985 suburban diesel 6.2 Qs . Im new , just registered 8/18/2012
Oldpackard
Tucson , AZ
Hi there , I have a 85 suburban with the 6.2 diesel that i just bought but it is wrecked and I'd like to know if the engine and tranny can fit a 1988 crew cab dually gas truck . If the engine and trans can fit I'll worry about the rest , Thanks everyone .
Yes it will fit. Pull the oil pan and look for mains cracks before investing 10 cents into the 6.2 swap.
do the crack check. it's easy to do now and can save a lot of extra work later. as far as the fit it was one of the options for the crew cab. there is no real size difference between the 6.2 and a 350 small block.
what transmission are you going to use? mostly just curious.
is the crew cab engine/drive train still in it?
I was thinking the suburban but is one stronger ? The dually had a bad 350 engine . By the way , if the engine checks out how many miles can you expect out of a 6.2 with good maintenance . Thanks
Shift points (trans governor) and torque converter will be very different between the two.
What's the fate of the wrecked 'burb?
