tracker954x4
- Messages
- 1,534
- Reaction score
- 0
Subject:Transmission Oil Cooler Line Leak (Replace Affected Cooler Line)
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2218713&from=sm#ss1-2218713">Condition
Some customers may comment on a transmission fluid leak. This concern will be more prevalent in extreme cold climates.
Further inspection may find that the leak is coming from one of the transmission cooler lines at the hose to steel line crimp.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2218713&from=sm#ss2-2218713">Correction
If the under vehicle inspection reveals transmission fluid leaking from one of the cooler lines, replace the affected cooler line. New transmission cooler lines have been released to address this concern. These new lines have been manufactured with an updated crimp process to better withstand the cold temperatures. Refer to SI for the replacement procedures.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2218713&from=sm#ss3-2218713">Parts Information
Part Number Description
20759971 -Pipe Assembly, Trans Fluid Cooler (Upper/Outlet)
20759972 -Pipe Assembly, Trans Fluid Cooler (Lower/Inlet)
20759973 -Hose Assembly, Trans Fluid Aux Cooler Inlet
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2218713&from=sm#ss4-2218713">
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
K9528*
Transmission Fluid Aux Cooler Inlet Hose - Replace
1.7 hrs
Add
To Replace Lower Pipe if Required
0.2 hr
K9529*
Transmission Fluid Cooler Upper Pipe Assembly - Replace
2.3 hrs
Add
To Replace Lower Pipe or Aux Cooler Hose if Required
0.2 hr
Add
To Replace Lower Pipe and Aux Cooler Hose if Required
0.4 hr
Add
With 4WD
0.6 hr
K9530*
Transmission Fluid Cooler Lower Pipe Assembly - Replace
1.5 hrs
* This is a unique labor operation for bulletin use only. This number will not be published in the Labor Time Guide.
Models:2006-2007 Chevrolet Silverado Classic 2500/3500 Series
2007-2009 Chevrolet Silverado 2500/3500 Series
2006-2007 GMC Sierra Classic 2500/3500 Series
2007-2009 GMC Sierra 2500/3500 Series
Equipped with 6.6L Diesel Engine (VINs D, 2, 6 -- RPOs LBZ, LLY, LMM)
Labor Operation
Description
Labor Time
K9528*
1.7 hrs
Add
0.2 hr
K9529*
2.3 hrs
Add
0.2 hr
Add
0.4 hr
Add
With 4WD
0.6 hr
K9530*
1.5 hrs
