tracker954x4
- Messages
- 1,534
- Reaction score
- 0
Subject:07293B - Transmission Overheat in Extreme Cold Ambient Temperatures - Reprogram TCM
THIS BULLETIN IS BEING REVISED TO EXPAND THE VEHICLE POPULATION TO INCLUDE ADDITIONAL 2008 MODEL YEAR VEHICLES IN FAR NORTHERN OR WESTERN PLAINS AREAS OF ALASKA AND MINNESOTA; CANADIAN YUKON TERRITORY, NORTHWEST TERRITORY, BRITISH COLUMBIA, ALBERTA, MANITOBA, SASKATCHEWAN, ONTARIO, QUEBEC AND NEWFOUNDLAND. PLEASE DISCARD ALL COPIES OF 07293A, ISSUED DECEMBER 2008.
THIS RECALL IS IN EFFECT UNTIL FEBRUARY 28, 2009.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss1-2080577">Condition
Certain 2006-08 Chevrolet Silverado HD and GMC Sierra HD model vehicles, equipped with Allison 1000 Transmission (RPO MW7); Duramax 6.6L Diesel V8 (RPO’s LLY/LBZ/LMM - VIN 2/D/6), may have limited or no transmission fluid (oil) flow through the transmission oil cooler after sitting for an extended period of time, such as overnight, during extreme cold temperatures, less than -40 °F or °C, excluding wind chill. If the "Elevated Idle Mode", cabin heater performance option is operative and the engine is allowed to idle for an extended period of 15 to 30 minutes while cooler flow is limited, the transmission fluid may overheat, resulting in transmission damage, and subsequent failure. These low temperatures only occur in, and therefore this program only includes vehicles located in, Alaska, Yukon Territory, Northwest Territory and far northern or western plains areas of; Alberta, British Columbia, Minnesota, Manitoba, Newfoundland, Ontario, Quebec, and Saskatchewan.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss2-2080577">Correction
Dealers are to reprogram the Transmission Control Module (TCM).
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss3-2080577">Vehicles Involved
Involved are certain 2006-08 Chevrolet Silverado HD and GMC Sierra HD model vehicles, located in Alaska, Yukon Territory, Northwest Territory and far northern or western plains areas of; Alberta, British Columbia, Minnesota, Manitoba, Newfoundland, Ontario, Quebec, and Saskatchewan, and equipped with Allison 1000 Transmission (RPO MW7) and Duramax 6.6L Diesel V8 (RPOs LLY/LBZ/LMM - VINs 2/D/6) engine and built within these VIN breakpoints:
Year
Division
Model
From
Through
2006
Chevrolet
Silvarado
6E104084
6E291953
2006
Chevrolet
Silverado
6F100522
6F271861
2006
GMC
Sierra
6E111614
6E291913
2006
GMC
Sierra
6F100786
6F271839
2007
Chevrolet
Silverado
7E100081
7E604034
2007
Chevrolet
Silverado
7F100047
7F567560
2007
GMC
Sierra
7E100087
7E604195
2007
GMC
Sierra
7F100066
7F567277
2008
Chevrolet
Silverado
8E100138
8E191831
2008
Chevrolet
Silverado
8F100062
8F203129
2008
GMC
Sierra
8E100409
8E191947
2008
GMC
Sierra
8F100073
8F202393
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using the GM Vehicle Inquiry System (GMVIS). Not all vehicles within the above breakpoints may be involved.
For dealers with involved vehicles, a listing with involved vehicles containing the complete vehicle identification number, customer name, and address information has been prepared and will be provided through the applicable system listed below. Dealers will not have a report available if they have no involved vehicles currently assigned.
-- US GM - GM DealerWorld Recall Information
-- Canadian GM dealers - GMinfoNet Recall Reports
The listing may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this program is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this program.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss4-2080577">Parts Information
Do not attempt to order the calibration number from GMSPO. The calibration numbers required for this service procedure are programmed into control modules via a Techline Tech 2® scan tool and TIS 2 WEB website with the following calibration updates:
2006-07 Chevrolet Silverado HD and GMC Sierra HD: Use data version 12.5 for 2007 or later, available on TIS 2 Web 12/17/07 .
Additional 2006-07 and 2008 Chevrolet Silverado HD and GMC Sierra HD: Use data version 2.0 for 2008 or later, available on TIS 2 Web 2/08/08.
If you cannot access the calibration, call the Techline Customer Support Center and it will be provided.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss5-2080577">Service Procedure
Notice: Due to the time requirements of programming a controller, it is recommended that an external power source be used to maintain system voltage. Stable battery voltage is critical during programming. Any fluctuation, spiking, over voltage or loss of voltage will interrupt programming. To ensure trouble-free programming, GM recommends using one of the following external power sources:
The ignition switch must be in the proper position. The Tech 2® prompts you to turn ON the ignition, with the engine OFF. DO NOT change the position of the ignition switch during the programming procedure, unless instructed to do so.
Make certain all tool connections are secure, including the following components and circuits:
DO NOT turn OFF the ignition if the programming procedure is interrupted or unsuccessful. Ensure that all control module and DLC connections are secure and the TIS terminal operating software is up to date.
Refer to the appropriate service procedure in SI to Reprogram the Transmission Control Module (TCM) Operating System and Calibration.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss6-2080577">Customer Reimbursement - For GM US
All customer requests for reimbursement for previous repairs for the condition will be handled by the Customer Assistance Center, not by dealers.
A General Motors Customer Reimbursement Procedure and Claim Form is included with the customer letter.
Important: (For GM Only) Refer to the GM Service Policies and Procedures Manual, section 6.1.12, for specific procedures regarding customer reimbursement and the form.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss7-2080577">Customer Reimbursement - For Canada
Customer requests for reimbursement for previous repairs for the condition are to be submitted to the dealer by December 31, 2008.
All reasonable customer paid receipts should be considered for reimbursement. The amount to be reimbursed will be limited to the amount the repair would have cost if completed by an authorized General Motors dealer.
When a customer requests reimbursement, they must provide the following:
Important: Refer to the GM Service Policies and Procedures Manual, section 6.1.12, for specific procedures regarding customer reimbursement verification.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss8-2080577">Courtesy Transportation - For US and Canada
The General Motors Courtesy Transportation program is intended to minimize customer inconvenience when a vehicle requires a repair that is covered by the New Vehicle Limited Warranty. The availability of courtesy transportation to customers whose vehicles are within the warranty coverage period and involved in a product program is very important in maintaining customer satisfaction. Dealers are to ensure that these customers understand that shuttle service or some other form of courtesy transportation is available and will be provided at no charge. GM Dealers should refer to the General Motors Service Policies and Procedures Manual for Courtesy Transportation guidelines.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss9-2080577">Claim Information
Submit a Product Claim with the information indicated below:
Repair Performed
Part Count
Part No.
Parts Allow
CC-FC
Labor Op
Labor Hours
Net Item
Reprogram Transmission Control Module (TCM)
N/A
N/A
N/A
MA-96
V1749*
0.4
N/A
Courtesy Transportation for vehicles within the New Vehicle Limited Warranty (US & Canadian GM Dealers)
N/A
N/A
N/A
MA-96
N/A
Customer Reimbursement (Canadian & Export Dealers/US CAC)
N/A
N/A
N/A
MA-96
V1769
0.2
* Labor operation valid for Repair Orders dated prior to February 28, 2009.
** Submit courtesy transportation using normal labor operations for courtesy transportation as indicated in the GM Service Policies and Procedures Manual for vehicles within the New Vehicle Limited Warranty.
*** The amount identified in the "Net Item" column should represent the actual dollar amount for courtesy transportation.
**** The amount identified in the "Net Item" column should represent the dollar amount reimbursed to the customer.
Refer to the General Motors WINS Claims Processing Manual for details on Product Recall Claim Submission.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss10-2080577">Customer Notification - For US and Canada
General Motors will notify customers of this program on their vehicle (see copy of customer letter included with this bulletin).
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2080577&from=sm#ss11-2080577">Dealer Program Responsibility -- All
All unsold new vehicles in dealers' possession and subject to this program must be held and inspected/repaired per the service procedure of this program bulletin before customers take possession of these vehicles.
Dealers are to service all vehicles subject to this program at no charge to customers, regardless of mileage, age of vehicle, or ownership, through February 28, 2009.
Customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the dealer listing, are to be contacted by the dealer. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. A copy of the customer letter is provided in this bulletin for your use in contacting customers. Program follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, whenever a vehicle subject to this program enters your vehicle inventory, or is in your dealership for service through February 29, 2009, you must take the steps necessary to be sure the program correction has been made before selling or releasing the vehicle.
December 2007
Dear General Motors Customer:
This letter is to inform you of a condition that can occur in your 2006-08 Chevrolet Silverado HD or GMC Sierra pickup truck when air temperatures fall below minus 40 degrees (-40° C/F) (excluding wind chill). If you do not operate nor expect to park your Silverado or Sierra outside for extended periods in far northern or western plains regions where temperatures may fall below -40° C/F, no action is necessary.
We have learned that your vehicle may have limited or no transmission fluid (oil) flow through the transmission oil cooler after sitting for an extended period of time, such as overnight, during extreme cold temperatures -40 °F or °C or less. If the "Elevated Idle Mode" cabin heater performance option is operative and the engine is allowed to idle for an extended period of 15 to 30 minutes while cooler flow is limited, the transmission fluid may overheat, resulting in transmission damage, and subsequent failure.
Your satisfaction with your 2006-08 Chevrolet Silverado HD or GMC Sierra HD pick up truck is very important to us, so we are announcing a program to prevent this condition or, if it has occurred, to fix it.
What We Will Do: To prevent this condition from occurring, your GM dealer will reprogram the Transmission Control Module (TCM). This service will be performed for you at no charge until February 28, 2009.
What You Should Do: If you do not operate, nor park your 2006-08 Chevrolet Silverado HD or GMC Sierra HD pickup truck outside for extended periods in extreme cold air temperatures of -40° C/F (excluding wind chill), no action is necessary. Most customers live in locations which do not reach these extreme cold temperatures. If you do expect your Chevrolet Silverado or GMC Sierra to be exposed to these extremes, to limit any possible inconvenience, we recommend that you contact your GM dealer as soon as possible to schedule an appointment for this reprogramming.
This is not the same TCM reprogramming we offered to customers in 2006. You should have this new, improved reprogramming completed even if the earlier reprogramming was completed. GM will reimburse you for the cost of the earlier reprogramming.
If you anticipate that your Chevrolet Silverado or GMC Sierra will be exposed to these extreme cold conditions before you can have the reprogramming performed, you can disable the "Elevated Idle Mode" to temporarily protect your transmission. "Elevated Idle" can be engaged or disengaged using the driver information center controls or by following the steps below:
1. Turn the ignition to RUN, with the engine off.
2. Press the accelerator pedal to the floor and hold while quickly pressing the brake pedal three times in less than eight seconds.
3. Release the accelerator pedal and start the engine
Customer Reply Form: The enclosed customer reply form identifies your vehicle. Presentation of this form to your dealer will assist in making the necessary correction in the shortest possible time. If you no longer own this vehicle, please let us know by completing the form and mailing it back to us.
Reimbursement: If you paid for TCM reprogramming for this condition before February 29, 2008, GM will reimburse you for the reprogramming cost. The enclosed form explains what reimbursement is available and how to request reimbursement if you have paid for repairs for this condition.
If you have any questions or need any assistance, just contact your dealer or the appropriate Customer Assistance Center at the number listed below. The Customer Assistance Center’s hours of operation are from 8:00 AM to 11:00 PM, EST, Monday through Friday.
Division
Number
Text Telephones (TTY)
Chevrolet
1-800-630-2438
1-800-833-2438
GMC
1-866-996-9463
1-800-462-8583
Courtesy Transportation: If your vehicle is within the New Vehicle Limited Warranty your dealer may provide you with shuttle service or some other form of courtesy transportation while your vehicle is at the dealership for this repair. Please refer to your Owner’s Manual and your dealer for details on courtesy transportation.
We sincerely regret any inconvenience or concern that this situation may cause you. We want you to know that we will do our best, throughout your ownership experience, to ensure that your 2006-08 Chevrolet Silverado HD or GMC Sierra HD pickup truck provides you with many miles of enjoyable driving.
Scott Lawson
General Director,
Customer and Relationship Services
Enclosure
07293A
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2009 General Motors Corporation. All rights reserved.
Models:Certain 2006-08 Chevrolet Silverado HD
Certain 2006-08 GMC Sierra HD
Equipped with Allison 1000 Transmission (RPO MW7); Duramax 6.6L Diesel V8 (RPOs LLY/LBZ/LMM - VIN 2/D/6) Engine
Located in Alaska and Minnesota; Canadian Yukon Territory, Northwest Territory, British Columbia, Alberta, Manitoba, Saskatchewan, Ontario, Quebec, and Newfoundland
Year
Division
Model
From
Through
2006
Chevrolet
Silvarado
6E104084
6E291953
2006
Chevrolet
Silverado
6F100522
6F271861
2006
GMC
Sierra
6E111614
6E291913
2006
GMC
Sierra
6F100786
6F271839
2007
Chevrolet
Silverado
7E100081
7E604034
2007
Chevrolet
Silverado
7F100047
7F567560
2007
GMC
Sierra
7E100087
7E604195
2007
GMC
Sierra
7F100066
7F567277
2008
Chevrolet
Silverado
8E100138
8E191831
2008
Chevrolet
Silverado
8F100062
8F203129
2008
GMC
Sierra
8E100409
8E191947
2008
GMC
Sierra
8F100073
8F202393
• A Midtronics PCS charger
• A fully charged 12V jumper or booster pack disconnected from the AC voltage supply.
• The RS-232 communication cable port
• The connection at the data link connector (DLC)
• The voltage supply circuits
DO NOT disturb the tool harnesses while programming. If an interruption occurs during the programming procedure, programming failure or control module damage may occur. • The connection at the data link connector (DLC)
• Proof of ownership at time of repair.
• Original paid receipt confirming the amount of repair expense(s) that were not reimbursed, a description of the repair, and the person or entity performing the repair.
Claims for customer reimbursement on previously paid repairs are to be submitted as required by WINS.• Original paid receipt confirming the amount of repair expense(s) that were not reimbursed, a description of the repair, and the person or entity performing the repair.
Repair Performed
Part Count
Part No.
Parts Allow
CC-FC
Labor Op
Labor Hours
Net Item
N/A
N/A
N/A
MA-96
V1749*
0.4
N/A
N/A
N/A
N/A
MA-96
N/A
N/A
N/A
N/A
MA-96
V1769
0.2
December 2007
Division
Number
Chevrolet
1-800-630-2438
1-800-833-2438
GMC
1-866-996-9463
1-800-462-8583
Scott Lawson
General Director,
Enclosure
07293A
