This is the in-tank lift pump module Dodge adopted for the '05^ CRD trucks, with similar factory-available retrofit to earlier CRD trucks, and VP44 trucks back to 1998.
Rated 5a and 10psi, it is a fully submersed, draw-thru when fail rotary-vane type pump, capable of maintaining rated pressure while supplying the HO engine at WOT.
This is the non-compressed position
Shows the wide range of tank depth, when compared to the first pic
This is the factory-available upgrade kit which fits the pre-'05 trucks
