no don't do pull the glow plugs. yet anyway.
You'll need to get all the bolts on the lower intake tightened down. I also see in your pic one of your PCM ground eyelets not connected along with a couple for the IP. don't worry about the two connectors that go to the upper intake. leaving the turbo and exhaust off is fine to crank and bleed the injectors. once it fires up it will just be a little noisy lol. Just be sure to plug off the oil feed line that goes to the turbo else you will have engine oil spraying all over. if enough oil gets into the intake while trying to start it, it can run and run away on you! if you can't plug it, you can possibly strap it so the end is secured in the opening of the oil fill cap or the open grommet of the valve cover, or even to the turbo oil drain pipe. Just make it so the oil going out goes right back into the engine.
having the thermostat crossover removed, as long as there is no coolant or water in the block where the water pump can make a gusher over the engine will be fine just don't run it very long.
you mentioned the engine was seized? what caused this?
Bleed the injector lines after you have the lower intake bolted and tightened down. get you a flat board or something flat and large enough that can sit flat over the opening on the lower intake, just have it ready in case it goes full throttle. it also needs to be stout enough that it's not gonna get sucked in. a clipboard is too thin. with all the wires connected to the IP. make sure you trigger the lift pump and you should start seeing fuel begin to flow out of the IP in the clear line you installed. once you have fuel there, you can start cranking. crank it for about 15-30 seconds then let the starter rest. keep watching the steel line at the injectors looking for fuel to start seeping out where the nuts are. depending on how loose they are, you won't see any spray or streams. as long as you see them get wet and run over the injector you have fuel.
stop and tighten up all the line nuts at each injector, say a prayer, and holler "Fire in the Hole" the engine should start up.
