Manny1500HD
Member
- Messages
- 21
- Reaction score
- 41
I had my transmission guy rebuild me a diesel transmission 4L80e for my 01 1500HD since my original trans the bellhousing ear was broken. plus all my hard part internals had signs of serious heat discoloration and surface cracks i gave him my orignal trans for a diesel trans with him installing the jakes performance rebuid kit. I already had the trucool 40k cooler with no thermostat control and i blocked off my stock radiator fittings for trans. trans has about 1800 miles on it, i live in ca and took a trip up to wrightwood and my trans was hitting 200F which was ok but when i got up a hill which wasnt very steep grade hill at all plus it was like 28F outside in snowing conditions my trans started to go up to 250F while my engine temp dropped from 205F to 150F i was just crusing up the hill at not even 15mph. whats going on?? i plugged in my snap on scanner to check for codes and look at the live data. the 1870 slip count was 0 at all times and TCC Slip Rpm was within specs from what circle D was telling me. the highest i saw on TCC Slip during full open throttle was near 800rpm slip and normal driving only got up to 500rpm slip. i did have the guy install the "shift kit" from Jake's but its still shifitng like stock feel. not sure if he enlarged the plate in the valve body. im running 20x12 wrapped on 33x12.50r20 tires. I'm planning on dropping the pan myself and correcting the shift feel to more firmer. i also dont have the heat shield that sits between the exhaust and transmission lines with my orginal trans wether i had that heat shield or not didnt make a difference in trans temp. what im going to do also is wrap the exhaust near the lines in exhaust wrapping to see if that changes anything. what should i do next? already dumped $2,700 into trans and a new torque conveter 2,200-2,400 stall. stock rear end gear ratio 3.73. even with my stock wheels i'd always have to stop on the pedal on the highways just to keep up.
