Dieseldad97
I now know why.
I also have this posted on the other site. I'll take any and all suggestions LOL. I need to do the top mount passenger side battery mod on my truck. Any 6.5 guys feel like posting a large pic. of what they did? Thanks.
basically all I did was cut the rubber boots off pos and neg, use a couple copper washers and no-ox greese with a bolt, nut and lock washer to tighten cables down. the rubber boots caused a gap and no connection on passenger side and ruined driver battery. top post, side post--doesn't matter, I have had the side post go bad due to heat and cranking load but the top was fine. the reverse is just as possible. make sure you have clearance on top post positive if switching to it.
Update: The mod has been done. :hurray: I cut the end off the cable that runs from the driver side pos. and fastened a terminal clamp to the top of the pass. battery. I then cut off most of the rubber on the other cable that runs to the starter and bolted it up in the side terminal. This making any sense?
Thanks for the help guys. I really appreciate it.
:nopics:
Lead bolts would just twist off first time you tighten them - Lead is very soft.
Steel is fine in this application. The idea is to get solid contact between the battery and the connectors - The bolt just keeps them there and shouldn't be conducting electrons about till you attach jumper cables. Even then the loss is insignificant.
Chi2, It's not so much an issue of conductivity as contact with all of the side post terminals, but none so much as the passenger side positive.
I stripped the insulation off that cable in 2000 and have used a SS bolt, a couple of SS washers and nut with the original lead spacer ever since with zero issues....Just run the bolt in finger tight and while holding the bolt head crank down on the nut to make a secure connection.
here are some pics of my side posts. washers are to make shure flat part of cables completely touch and crimp part of connectors do not touch and create a gap. copper is best connector unless you want to buy silver, use no-ox to inhibit corosion/oxidation on connectors.
So this is what I did.
