But if the injector pops at 2100psi, then regardless, the first fuel coming out (or not if cylinder pressure is higher) is at 2100psi, even if the plunger pushing behind it will push it to 5000psi or higher. So what if youre running 40psi of boost with a 21:1 CR, at what point does your injection get over the 3500psi cylinder pressure while the pintle is opened at 2100psi not able to push the fuel out yet? I see this as quite an issue and fuel might heat up and want to burn at the tip. The injection event may only be 20ms, but that fuel pressure will have to ramp from pop pressure to final pressure. And what is that final pressure at what rpm and fuel rate? What if at 2500rpm and 100mm^3 it usually only hits 5000psi, then your fuel pressure to cylinder pressure ratio is still way lower than it would have been in a stock system that was never meant to go over the pop pressure. Its no wonder that GM increased the pop pressure from 1800psi on NA engines to 2100psi on turbo trucks. Because an NA truck will see 1000psi air pressure max at TDC, but with 15psi of boost youre looking at 2000psi, or under stock conditions of about 8psi of max boost, there would be a 600psi margin over pop pressure, just like NA had 800psi margin.
No one thought about maintaining that margin, except the guys that decided to go common rail so that fuel comes out at more pressure than youd ever have to worry about with even 100psi of boost.
Although I'd be willing to accept its a problem on the back end of injection as well.
