I'm bored and can't sleep so I decided to do a little research to bring all up to speed on what has been done to this truck since December.
Looking back through PsychBilly's thread"
-Code 12 when jumping the pins...
-"I only got fuel to the t-valve when the engine is turning over good. When the batts were weak I got no fuel to the valve."
-"I tested the LP pressure and it's only making about 3-4 psi. It also took it about 40 secs to pump a quart out the t-valve."
-All eight GPs did eventually get changed with 12v at all eight. WTS light was staying lit for up to 15 seconds.
-One battery was down on CCA, 450 vs 600.
-Cracked a line at some of the injectors and no fuel during cranking.
-Did not swap in a different lift pump
Pneese973 has:
-code 12 when jumping pins...
-started the truck cold or hot on slight ammounts of ether
-charged the batteries with a 100A charger and jumped it with another vehicle
-Filter was bled with a bottle and clear line with small amount of bubbles observed
-ran the pump and got about a quart of fuel out of it and closed the filter drain with the pump running. No indication of the time it took to get the quart of fuel or whether the truck was running or not while being bleed
-"The lift pump will run when jumpered or I can hear it for a few seconds after I stop cranking, so I know it's running" (not clear if he was checking LP output during this process)
-Stated, "It can't be a bad lift pump or a hole because I get fuel out of the filter when I crack the bleader and run the pump-installed a new PMD on a remote to the bumper"
-unplugging (one at a time) the coolant temp sensor, IAT sensor, and the map??? sensor and tried starting it and no luck
-confirmed the weird smelling fuel PsychoBilly reported
-observed the truck has a funny smell out of the exhaust while cranking (like stale fuel) and "I saw smoke out of the exhaust while trying to start it"
Not sure if this helps but at least it gives a one stop reference point.
Besides, Pneese is obviously smarter than me, has logged off and is getting some rest.
I don't know about smart than you, but I have a busy next several weeks ahead of me, so the truck can't consume all my time. I appreciate all the help guys, but I need to do some testing before I can answer some of the questions. I did have a detail conversation with Turbine Doc last evening and he gave me quite a few ideas and after talking through it, it's very likely possible that I'm not experiencing the classic problems that you might expect. I also spoke to psychobilly last evening and he told me he had 4-5psi at the T Valve and that the other LP was good. After getting the truck, I think some routine maintenance was overlooked (for instance, I dont' think the injectors have ever been rebuilt). After putting everything together, here's my plan of attack....
1) change out LP with a known good one
2) change out injector nozzles with a new set of marine nozzles. I also have a pop tester, so I will pop test all the injectors and see if they have a good spray pattern before reinstalling. I ordered the marine nozzles last evening.
3) I just got a new battery, so I am going to install it.
4) bypass LP controls so it's always on with the key (at least for debugging)
5) check glow plugs and relay
6) try unplugging optical sensor since IP looks like it's never been off and may likely be bad
7) try advancing IP because we're very suspicious the problem I have is a dead stepper motor (it acts like it's retarded while cranking)
After doing this, we've eliminated the PMD, lift pump, fuel filter, optical sensor, glow plugs, and injectors.
psychobilly wasn't getting fuel to the injectors while cranking, but I know they're getting fuel after installing the new PMD because I've seen black smoke out of the exhaust while turning it over. It almost seems like it's getting fuel but at the wrong time which leads us to believe it's the stepper motor. Remember, even my friend said it rattles more than his '95 which would be a timing issue. One other thing, is even warm, in or out of gear, I have a high idle at about 1000RPM's which I'm sure is related to the problem.
