I install the rotor in an 8cyl head,it must be exact fit,I have several to choose from,and then go with one that is snug but not to tight,its all by feel. This pump came with the bigger drive slot,so I will need to get a spacer made to mate this rotor to the 6.5 pump drive shaft,my other 4 plunger head and rotor had the correct slot for the shaft. I will try to put as many db4 parts into a db2 housing that I can,the advance piston is the same diameter ,and the cam pin is way bigger and better,so a db2 cam ring will need to be machined to accept the pin,the ag style governor is interesting,but more difficult to remove than the automotive style , I believe with the right spring, an ag governor will give more fuel,because it looks like it could be easier to get more travel out of this set up,but it will not easily swap into the db2
