matuva
Tropical 6.5er
:bigear: :bigear: :bigear:
Guys all these things are possible, just need a design drawing and we can get a quote. The manufacturing possibilities are amazing. A p400 block would be possible but a bolt on addition to our block would be easier, If anyone has a drawing or print I may be able to get a quote, Chinese cast iron is second to none, to bad we closed most of our foundries.
Just like everywhere else, itt has been my experience that you have to know the right people in China for things to go smoothly.
I'd like to see a cast upper manifold that looks factory and has a smooth transition from the ATT to the lower intake manifold. It should look good on its own or allow the use of the plastic engine cover if so inclined.
Well and maybe not decrease to that tiny inlet area it does now. The rectangular area of the opening from the 90 degree bend into the intake is smaller than the circular area on the rest of it. Thats why I bought the 6.2 type that fits the 6.5, because it has a 3" inlet it looks like and I can use larger pipe then from the turbo.
Buddy I run a 2.5 inch to 3. inch adapter off of the turbo and then run three inch pipe to a plate with a three inch opening. The air temp sensor is in the three inch pipe between the two.
We would need a design spec drawing, then need material specs and machining specs, tolerances or we pay for all that to be done. I like the idea of a bolt on main girdle. Need an oil pan to go with it. It is an idea, we have enough of the rite people here to do it.
That was exactly my plan until I just bought that Peninsular intake. The plate with a 3" stub on it might work better though so I only need to 45 degree it vice 90 degrees.
Hell, I'll make my own pan!
Just get me a girdle in raw or finished form!
Gawd, I never thought I'd be saying "I need a girdle" at 45 years old.....
):h
I'd like to see pics of what you guys are talking about. All I can envision is a plastic flexible pipe that I've seen on a couple installs.
I can ask, I just need a drawing, with a material spec, (Cast iron would be easiest) I think.
I would be very interested in a bolt on main girdle if the price was within reason. I just dont know for your sake if there is enough of a market for the product. But it really is nice seeing new inovations being marketed for these trucks.
