diagnostics
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). ____________________________
Demographics: tell us about your truck and your ambient conditions:
- Year: __1995____
- Truck model and class (ie: c2500) __2500 suburban_______
- Automatic or Standard _____auto_____
- Mileage: (indicate miles or km) 265000_________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ___________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? __s____turbo________
- Ambient outside temp: (indicate *C or *F) ____65-75 f______
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ____bio_____
- What fuel additives are you using? ___none________
- Where are you located? ______NY_______
General maintenance: inspect and evaluate the condition of each. When were they last changed?
- Air filter _________
- Fuel filter _________
- CDR Valve? _________
- Coolant – last flushed/replaced at __replace with swap___________
- Oil – synthetic/regular, changed at __regular replace with swap_________
- Batteries – state of charge, (matched set) replaced at ___matched__________
- Battery cables and grounds (removed, cleaned and tightened): _____removed cleaned tightened and doubled_________
- Glow Plugs - how many miles on them? ___?????______ What type? ____delco_________
- Injectors - last changed at ___????____________
History: (Describe how the problem first appeared.)
- What were you doing when it happened? revving in the driveway
- How was the truck running fine before this problem appeared? ______yes_______
- Has this problem ever happened before? _no______________________
- Describe any related factors that might be part of the problem. codes hard start __________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) ___y_ And? 17 18 35
Diagnostics:
1] Starting:
1a] Does the engine start? ____y_____
1b] Does the engine crank over? ___y_____
1c] Are your batteries fully charged? ____y_____
1d] Have you removed, cleaned, and tightened all battery connections? ___y_____
1e] Does your Wait to Start light come on for a time? How long? _____y ___
1f] Does your glow plug light come on? ___y______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? ________
1h] Does the Service Engine Light Glow during Start/bulb check? __y______
2] Fuel Issues (if not running):
2a] Can you hear your lift pump working? ____y________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? __y_______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ____y_______
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) __pump will remove soon_________
3b] Condition of Extension harness (if used) Vendor or Homemade? __na_______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: ___________
3e] PMD Age: _____________
4] Stalling Issues
4a] Do you experience stalling only when hot? _____n_______
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ____n__
4c] Does pouring cool water over the IP seem to help with restarting? _________
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? _________
4f] Does cruise control quit working when engine hiccups? ___________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ___n____
5b] Any bubbles or oil film in coolant overflow tank? ____n___
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _____n_____
5d] Excessive white smoke from exhaust on cold start? ___n______
5e] Excessive black smoke from exhaust under hard acceleration? ___n_______
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? _n__________
6b] Maximum boost under load? ______na______
6c] Have you added a performance PCM (reflash) or Chip? _____n_________
6d] Have you changed exhaust / downpipe / crossover? ______n__________
6e] Wastegate – mechanical or vacuum (OEM)? _____oem_________
7] Temperature-related Issues:
7a] Single or dual thermostats? ______single______
7b] Have you replaced them lately? Manufacturer of replacements? _____n____
7c] Have you pulled and cleaned Radiator and coolers lately? _______y_____
7d] Have you replaced the fan clutch? Manufacturer of replacement? _____n___
7e] (winter) Have you tested your antifreeze? Good to what temp? ____n______
7f] (winter) Are you using a winter grille cover? _____n______
n
List and describe any other factors which are not addressed in this checklist. We can’t see, hear, smell, or touch your truck, so the more descriptive information you can give, the more likely it is that somebody can assist you.
The motor was just replaced with a doner Jasper 6.2 crate engine
It ran great but I had some return line isues
I pulled the tank and fixed the return line
It started back up and I drove it around again
A day or to later I was fiddleing with it in the drive way when reving the engine to 3000 it started to break up
now it breaks up around 2800 (right before shift @ hard accel)
it starts hard....turns over great but has to crank for 25 secs or so first even after warm
It stays at high idle and those were the last 3 codes I got
