625fireman
I have injecter-itis
Steering stabilizer shock???
TD- changed out those bearing/abs hubs due to ur strong suggestion. When I R/R the front end I found a hidden gem - a set of yellow bilstien shocks!!
Buddy- Here is the tire situation. After I, got the front end complete, I put the torsions bars back where they sat(almost cranked all the way) and drove it for an alignment(not pep boys). Immediatly I could feel the stiffness(not vibration) at low speeds. Got the truck back went work(without a hwy test(BAD IDEA) and the ride had my teeth chattering. Found out one of the Dueler A/T had bulged on the footprint area. This was a matching set 285/75/16 ( balancing- dyna ceramic beads inside tire). Put the spare on - smooth as silk. Pick up a pair of 305/70/16 , mount em, slight interment vibration.
Now I have 305/70/17 Mud Dawgs(traditional balance w/lead weight Pep Boys) on Pro Comp Alloys, the truck still sits in the new position the alignment guy put it in- almost level to have it ride smooth. There is no lift on the Tahoe (onlyslight rub on hard turn+elevation lol!) Also Ive accounted for spedo difference on tire size via tire calculator.
I would think it would help a ton with the large tires.
Large and / or heavy ithelps. Mine came with one factory, not sure where the cut off is for factory requirement.
Nope, Just stock load rated E tires. I rotated the tires to see if it was a bad tire but the vibration remains in the same location. I also put the truck in neutral while at highway speeds and the vibration didn't go away so I ruled out engine vibration.Ireburb are you also running very large (tall and wide) tires?
I am very interested in this thread. I have had the same problem and finally gave up after the mechanic couldn't figure it out either.
Replaced the transmission mount and both u-joints. All new shocks, tires balanced, balance beads.
Good luck and I share in your search for the answer.
balance beads
