OK, so here is what i did wrong.
I am a type A personality, i cannot handle if something does not work.
anything NEEDS to be fixed immediately right then and there.
I am sure some suspected that I
MIGHT be anal-retentive and plagued by Obsessive Compulsive Disorders ;-)
All i would have had to do is wait 3 hours for morning to come around in Ellensburg, WA and ask Bill Heath.
he carefully listened to my symptoms, thought about it for like 25 secs and said:
Nick - I want you to crack open the fuel cap so there is no vacuum created in the tank. It sounds like there is a fuel "leak" and that the vacuum is causing the fuel side to draw in air.
I did as the Obi-Wan Kenobi of 6.5s said and I thought I will be damned. the truck has started as normal ever since then
EVERY SINGLE TIME. Bill's further instructions was to wash out the valley underneath the intake and monitor and see if i can find the leak.
A similar occurrence for TurbDoc was caused by just "lossened" clamps on the fuel lines on the bottom of the fuel filter manager - so I am keeping an eye out, since i cannot find a leak and will change them lines and replace the clamps with real hose clamps.
But seriously - the truck really has not skipped a single beat after loosening the fuel cap. I wanted to kick myself for not showing patience and waiting to asking....
But now the force is strong in me again ;-)
All that is still bugging me is the rattling heat shield now and I just might sneak out one night and take out the turbo just to fix that ;-)
