Well with these trucks you should be able to pull off better mileage than that. The fuel filter I changed right before we left. The air filter was good according to the indicator but I'll check that before we leave for home tomorrow. We drove anywhere between 70 and 78mph. When we drove 70 the dic said 9.8 mpg. 75 and higher was in the 8 mpg range.
He has Goodyear Wrangler Silent Armor 265's and the speedo is off by 2-3mph. Is it safe to say we're getting maybe 1mpg better than the dic thinks because the tires throw it off?
I know it's a truck but dropping 10mpg on the highway seems a little crazy just by pulling a 3-4k pound pontoon. It doesn't struggle whatsoever.
Another thing I noticed....if he hammers down on it unloaded it'll blow a little black stream of smoke....is this common for stock tuning? I know mine didn't do that but his has more power stock also.
First of all, you might as well throw away that little filter minder thing. Those are completely worthless and should not be used to judge how well its flowing. Its its blowing black smoke, that means its overfueling and not getting enough air. Basically, on a stock truck, I'd bet his filter is shot and isnt allowing enough air to get in so its dumping fuel. Its the only thing that makes sense.
Yep. If the speedo is off, so is your mileage. Its not accurate anymore so its impossible to tell how many miles you've actually gone with gallons burned. You're short changing yourself.
If its off by 3, then with the speedo readin 60, you're actually doing 63. So in 120 miles on the odometer, you actually traveled 126 miles. In 1200 miles, you actually traveled 1260. Unless my math is off, which it probably is, there's no way to accurately calculate your mileage.
I have to do this on my car since I'm running 18" wheels instead of the stock 16's. My speedo is off by 4 mph at 60. So in every 300 miles driven per tank, I have to add 30 miles to it to get an accurate number. And last tank of fuel it was the difference between 17.5 mpg or 20.5 mpg actual mileage, using the difference in the speedo.
3 mph may not look like much but over the course of an entire tank of fuel, you're losing 20-40 miles that should go to your benefit.
