Nor-Cal Nick
Suspension Consultant
We are now offering Sulastic Rubber Springs at Nor Cal Truck. I might not have them on my site for a while but till then you can call your order in or PM me. Here is a little about the product if you don't know about already.
Making Vehicles safer and high performance enjoyable !
What is Sulastic ?
SULASTIC is an elastic (rubber spring) suspension that reduces and in many cases totally removes the vibration and shock caused by the leaf spring suspension, improving safety and overall handling of the vehicle.
Key benefits
-Increase in vehicle stability by 20% to 30% increasing the angle for turn-over by 4 to 6 degrees
-Reduction in vehicle vibrations by 60% to 80% while significantly reducing excessive tire temperature caused by excessive vibrations
-Reduction in braking distances by 10% to 20% keeping all 4 tires on the road during braking
-Increase in driver control by stabilizing vehicle weight over all 4 tires
Sulastic Shackles in my words:
Sulastic shackles basically are rubber isolators that takes the top heavy spring rate off these 3/4 & 1 ton trucks when driving down the highway or city streets. In a way making your factory spring into a "progressive" style ride and at the same time not reducing your spring weight capacity.
On my personal truck:
2008 3500HD Dually Crew Cab Long bed
I run the Sulastic Shackles and my personal spec'd Bilstein (Zinc) 5100's for daily driving and when I pull my fifth wheel trailer (about 18k) I have AirLift helper bags to accommodate the heavy fifth wheel pin weight. Great ride to the point that my family and I really do enjoy driving the truck for short or long trips.
Nor-Cal Nick
What is Sulastic ?
Key benefits
Nor-Cal Nick
