Are you taking about a factory TCM or tuning a PCM by making it into a standalone just for the transmission? I would like to learn how that can be done on these older OBD1 trucks!Just us a GM 0411 PCM. Tune it with a tune for whatever crank sensor teeth you are using (i have a crank gear on my 6.2 from a 6.5, which is 4x) my PCM has a 00-01 van 5.7/4l80 tune, then we went in and turned off all the engine perimeters but crank sensor, TPS & CTS.
Took all the unnecessary wires from a factory harness and good to go. How I run my 4l80
Just a $30 junkyard ECM, 12200411 used from 99-02 on just about every Style of GM vehicle.Are you taking about a factory TCM or tuning a PCM by making it into a standalone just for the transmission? I would like to learn how that can be done on these older OBD1 trucks!
