As you can see in another post my 6.5L is as well oiled on the OUTSIDE as it is on the inside at the moment. :blindfold:
What do I have to do with the rebuild for heavy duty use? Where do I get parts like ARP head studs and new pistons?
I already have the temperature under control with mods as it does not go over 210.
It may have been just an injector failure and this thread is not necessary? I have 2 injectors out and I am pulling the rest now.
Max boost is in 4th, OD at 13-14 PSI below 2500 RPM.
Pyrometer was scheduled to be installed this weekend with a new LH exhaust manifold. Except the engine went first…
The route I have towing has a lot of hills. Basically I put it on the floor and leave it there for an hour. Speed changes to as low as 43 MPH. (Phoenix to Payson.)
A Cummings swap will not do me much good. The late model Dodge… It will keep speed, but, if you slow down it will not speed back up. The other Dodge committed suicide and popped a $1000.00 computer that got me this route as the Dodge owner did not fix his truck.
So do I put in 18:1 pistons?
Do I rebuild it stock compression? (And hope the new ceramic coatings prevent this issue again?)
Do I get a 6.2 military take out, lower the boost and use it?
The ATT turbo looks like a good choice, but, I have a hard time justifying the additional cost on top of a rebuild with a working GM3 and the value of this truck.
What do you recommend for this type of use? Is this a bad engine choice for what I need – wrong tool for the job?
