matuva
Tropical 6.5er
Hi all,
this post is a duplicate of the one I did on DP. The guys are answering me, and show some path I will explore.
That said, I miss some of you, so I post here too
here's the story :
thursday, a friend with a 1995 K1500 took 3 hours to come back home after an 80 kms trip : his tranny was stuck on 1st gear... At the end of the trip, he was a bit "nervous" and rev the engine up to red zone and felt a chock : the tranny accepted to engage 2nd, but no more
Today, we changed his Trans, swaping from a NP 241C to a NP 243C. (Hope they are interchangeable, aren't they?)
Still stuck.
We hooked a laptop for DTCs reading and found these :
Still stuck
Though, only following code remains :
38 TCC brake switch stuck OFF
So, we don't know what is this TCC brake switch. We don't know what TCC means (any?) but we saw the brake lights were not working anyways and so pulled out the brake stop switch, cleaned it out, made the stop lights working again and went for a test drive : Still stuck, code 38 disappeared but new codes show up! :
With the software (GMTDscan), I was able to force the shifting. The tranny shifts that way, but stays set on the gear I forced e.g, if I force up to 3rd, it stays on 3rd, even if you stop.
We are a bit lost and discouraged. Any of you get an idea? Another ground story? or PCM giving up.
My thought at the moment is that we are facing an electrical gremlin rather than a mechanical one...
here's the story :
Still stuck.
24 vehicule speed sensor circuit low (Trans output speed signal)
72 vehicule speed sensor circuit loss (Trans output speed signal)
Still stuck
18 pump cam reference pulse error
36 injection pump width error (response time long)
54 PCM fuel circuit error
