PhattDaddy94HD
Hey gang, I installed the new lift pump today. Easy, straightforward install but, it wouldn't work when done. I found out that the ground wire in the foctory plug had a problem. Once I grounded the pump directly to the frame it works great! The truck runs the same but now I have fuel pressure reading on my new gauge (9-10 psi at idle down to 4-5psi at WOT). Truck had a cold start issue before (it would start, run for about 30 sec. then die. Then had to crank for awile to get fuel back up to injector pump). Fuel pressure comes up quick now so I think that problem should be gone, also had an occasional stutter under hard acceleration. I will be driving it way too hard in the next few days to "check it out". I always love a good reason to play. Next order of business is to remove the intake to relocate the PMD. I'm also planning to install #9 resistor, ALWAYS LOOKING FOR MORE POWER! Burnin Oil has been great help through this project so THANKS AGAIN! Leroy! Talk to you soon, Jeff
