Will L.
Leroy’s new reusable valve cover gaskets sparked an old thought I had for better power and efficiency. By eliminating a lot of the fight it would take to work out the kinks.
I have never liked the non adjustable valve rocker arms and plastic buttons. Infact- that set up is just expected in quailty diesel engine design. But with the nightmare of injector lines and the valve cover destroying/ sealing design- it isn’t worth the fight. One of my “what if” improvements was a set of solid roller lifters with adjustable roller rocker arms. But a 2 piece valve cover would be a requirement for that which is as much work as the rocker arm mod itself. These gaskets combined with some QD connectors at the ip side to make lines easy for in n out could be done much easier. Doubt at this point I will ever get that mod done, but maybe one of you all could run with it.
