Jasondt2001
Lead Slacker
Ok, Well i decided to do the trans-go Jr. install with the hoot flush method after...
I unfortunately had no lift, and decided I had other uses for my floor jack (thank goodness I had it available!).
There's no special tools or anything needed for this...
To be honest I think I only used a 12mm 15mm and 14mm sockets, an extension and ratchet, a torque wrench, a flat blade screw driver or hooked scribe.... oh, and a drill!
Guys - this is just basically an outline to R and R the valve body... I did not include instructions on installing the transgo as if it ever changes I don't want people relying on a outdated post because they won't read the instructions that come w/ the product.
It's about as detailed as I could get with tranny fluid all over the place, and a camera in hand... :spit:
OK enough talking! On to the pics!
1. Drain Fluid
OK, Dropping the pan is pretty self-explanatory... Put the drain plug back in the drain pan...
Then take all the pan bolts off EXCEPT 2 on opposite sides... just loosen them.
Put your hand on the middle of the pan bottom, push upwards, then take the 2 loosened bolts out of the pan and slowly bring the pan to the ground.
KEEP THE PAN LEVEL - You will see why in the bottom pics...
Once on the ground, I used the pan to let the valve body and filter continue dripping and draining into the pan itself.
OK - Time to remove the internal filter... yes this is one that is OVERHAUL ONLY... Well if I had the right filter that was sold to me, I would have replaced it - it's SOOO easy. I always hear "only during overhaul" and I think it'd be hard to get to, and horribly hard to change! :baby:
So, to get it off, put your hands on it, twist and gently pull down... It will come off in your hands.
It will also bring QUITE a bit of tranny fluid with it - so be prepared to let it drain. I put it back in the trans drain pan and let it drain... only because I had to re-use mine (I was sold the wrong one).
Ok - Deep breath... Now it's time to get into the valve body.
First thing, unhook all of the electrical connections -
Another View:
Watch the hidden one!
1. Drain Fluid
Another View:
