mattthebrat
Diesel Dork
I have seen many questions asked about taking apart these doors, so as long as I had an extra door to play with, I decided to do a write up on it!!
If there is anything I missed or didn't explain enough, feel free to ask me or correct me.
Removing The Door Panel
1. Remove the inner handle trim by prying from the inside out, like this:
There are four tabs that hold the bezel on (Red Arrows)
2. Remove the light by prying out on the back and then pulling the light backwards out of the hole.
3. remove the two screws in the armrest:
4. Remove the switch panel by prying up. Be careful of the plug on the mirror switch. Many people forget about the clip(Red Arrow), or just say screw it and break it off.
5. If you have crank windows you will need a crank removal tool. They are about $10 at any auto parts store, or you can build one yourself, like I did.
6. Remove the filler panel by the mirror
7. Pop the plastic clips out, a clip tool may be helpful for this.
There are 9 clips that hold the panel to the door (Red Arrows)
Now just pull up on the panel and push in at the top to release it from the window channel.
And thats it!!
And thats it!!
