Mezmorized
Hi, I bought a 95 C2500 ECLB 6.5 Turbo 4L80E in May 2010. Since then the left signal light flashes fast. At the time, the tail lights were of the aftermarket clear variety. Thinking that may be the problem (and I don't like those tail lights) they were replaced with OE style tail lights. Problem was still there. I then picked up a flasher relay... Well, I can see there is a problem somewhere... The new relay I had tried in the place of the old one would blow fuses when I put the left signal on. The parts numbers were different but I don't think that's an issue. I have yet to pick up a relay with the same part number on it (sort of put the repair on the back burner) to see if that will cure it, but I doubt that.
Can anyone give me an idea on where to start diagnosing this problem? Or anyone had the same problem? There are no lights that are burnt, and none are on dim either.
Just in case... This truck is not equipped with air bags and is a Canadian vehicle, so it has daytime running lights.
