coxpn2
coxpn2
I did quite a bit of searching about airbags, re-arching springs, spacers, etc. Unfortunately, I haven't really seen much feedback from anyone that's done them - the info is presented, but not too many people are commenting on what they liked/disliked. (Or maybe I found the wrong threads
My suburban sits lower in the back than I like. If looking at it on level ground, unloaded - the back is maybe a 1/2" to an 1" lower than the front. Not really noticeable, but mildly annoying. However, drop a couple hundred pounds of trailer tongue weight and it drops even more. This looks dumb, and isn't really safe/stable I wouldn't think.
I also have air shocks, which don't appear to hold air. I haven't crawled under to check out where it is leaking, for now I'll just assume the shock itself is and that I need new ones. (Although if you bump pressure of shocks up to 50 psi the rear does pick up, just won't hold air). And I do know you cannot just pump air shocks up to lift the back, or you'll transfer all of the load to the shock mounts and snap them off... I know that response is coming
My initial thought was to just put airbags in it to put the rear back up where it needs to be. Looks like you can get them for around $300 (minus the compressor). However, I would still need to get new shocks. The bags would only act as the spring; I still need the dampening action of the shock, correct?
And assuming I use the bags to level the rear of the truck - what would that do to ride quality? If I need 85 psi to jack the rear up higher, is it going to bounce around all over the road with so much pressure? Or can you put 100 psi into the bags and not notice any difference in ride quality? I wouldn't think this would be the case... but I don't know.
Another option I'm finding is re-arching the springs. I'm not sure what shops do this, but would this accomplish what I need?
Another option is buying new leaf springs.
I'm not really sure what would be the most economical way to go at this point. Money is obviously not growing on trees, but if the 'correct' action is to put new springs in then I'll do it. If re-arching works just as well and will only cost $50 and my labor, I'd go that route. If airbags will do what I need and give me adjustability of the rear height, maybe that is the way to go... I'm just not sure!
Let me know what you guys think. Thanks again
