LML rear pads and rotors for SRW - single rear wheel
VW_Lupo_TD
Active Member
in quiet
ordered by mistake as a single rear wheel setup for a 2013 GMC Sierra 3500 Duramax Dually DRW -
only used the fronts and the rears are BRANDNEW in the bags / box.
POWER STOP Z231411 [Brake Pads rear] Z23 Evolution Sport; Carbon-Fiber-Ceramic; Includes Hardware
POWER STOP AR82155XR [Rotor] Extreme Performance Drilled and Slotted; Rear Right
POWER STOP AR82155XL [Rotor] Extreme Performance Drilled and Slotted; Rear Left
check if it fits yours using the part numbers above and get a killer deal - especially if you are local and can pick these up.
Each rotor sells for $121 on rockauto and the pads for $60.
over $300 worth of parts for​
$200 OBO​
picked up !!​
the pads according to rockauto fit all of the following
CHEVROLETEXPRESS 35002010-2018
CHEVROLETEXPRESS 45002009-2018
CHEVROLETSILVERADO 25002011-2015
CHEVROLETSILVERADO 35002011-2015
GMCSAVANA 35002010-2018
GMCSAVANA 45002009-2018
GMCSIERRA 25002011-2015
GMCSIERRA 35002011-2015
