I'm going to post all my tuning efforts here. So far I have driven about 10 miles,and currently the engine is getting new head gaskets. Here are some observations while it was running. The axle gearing feels plenty high,3.42's. The converter feels plenty loose also. The torque converter lock up slips while engaging under full power. The injector pump is a stock db2831,with the screw tight. The advance screw is turned out very far,this is how it was. With my high compression,it seems to be getting to much timing. I bought a Snap On MT 480,but I'm missing the glow plug adapter. With a temporary boost gauge it made 25 psi, but never lit. It spooled gradual ,but never felt lag either,thanks to a very high factory stall converter. Also it hits the governor early,and cuts fuel,not real far beyond the stall speed. No tach yet. From a dead stop there was only a puff of smoke. Lugging it in 3rd it smoked a fair amount. Free revving also got a fair amount of smoke. At idle the exhaust smells like a newer diesel,I think this is from the compression ? Also my lift pump is cavitating. I'm pretty sure that some governor work will make it come alive. Sounds to easy don't it ?
