6.5quest
So here is my thought, I have been working on the project 350hp truck for a while now and realized how good of a test truck this would be for a PCM test. No one to my knowledge has run a Heath, Kennedy, SS, ext. PCM dyno/hill climb test. So I have started talking to some of the manufacturers of the PCM's and might be able to do a separate article on at least 3 of the top programmers for the 6.5L.
The test would be done the same day we do the HP record run but then change the truck back to a GM-8 turbo and run at least 3 different PCM's 2 times each. After that we have a very steep and long hill that we could run a 1000 foot test to see who runs the fastest speed, quickest time, and lowest EGT's.
Just wanted to see how many of you would be interested in this article if I can make it happen?
Ian
Ian
