stacks04
McLovin
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). p0236 and p0238 codes
- Year: _1997_____
- Truck model and class (ie: c2500) __k2500 suburban_______
- Automatic or Standard __auto________
- Mileage: (indicate miles or km) ___115k______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ___relocated driver________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? _____f_________
- Ambient outside temp: (indicate *C or *F) __60's________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) __bio_______
- What fuel additives are you using? ___n/s________
- Where are you located? _____ct________
- Air filter ___recent______
- Fuel filter ____"_____
- CDR Valve? ___n/s______
- Coolant – last flushed/replaced at _____recent________
- Oil – synthetic/regular, changed at ____recent_______
- Batteries – state of charge, (matched set) replaced at ______good_______
- Battery cables and grounds (removed, cleaned and tightened): _____good_________
- Glow Plugs - how many miles on them? ___n/s______ What type? _____gm________
- Injectors - last changed at ______n/s_________
- What were you doing when it happened? ____towing__________
- How was the truck running fine before this problem appeared? _____fine________
- Has this problem ever happened before? ________few times_______________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _y___ And? ___p0236 p0238_____
Diagnostics:
1] Starting:
1a] Does the engine start? ___y______
1b] Does the engine crank over? ____y____
1c] Are your batteries fully charged? __y_______
1d] Have you removed, cleaned, and tightened all battery connections? ____y____
1e] Does your Wait to Start light come on for a time? How long? ____few seconds_____
1f] Does your glow plug light come on? _________ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? ___n_____
2a] Can you hear your lift pump working? ____________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ___________
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: ___________
3e] PMD Age: _____________
4] Stalling Issues
4a] Do you experience stalling only when hot? ____________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4c] Does pouring cool water over the IP seem to help with restarting? _________
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? _________
4f] Does cruise control quit working when engine hiccups? ___________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? _______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __________
5d] Excessive white smoke from exhaust on cold start? _________
5e] Excessive black smoke from exhaust under hard acceleration? __________
6] Performance Issues
6a] Do you have gauges? ____no_______
6b] Maximum boost under load? _____n/s_______
6c] Have you added a performance PCM (reflash) or Chip? _____no_________
6d] Have you changed exhaust / downpipe / crossover? _______no_________
6e] Wastegate – mechanical or vacuum? ____vacuum__________
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? ____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
thanks guys, not much of 6.5 guy, got into diesels after the duramax so i am not up to speed on the older stuff. i know the codes are a signal voltage high and turbo performance. just not sure where to start. it is a side job i have and i drove it many times and cant get it to act up, it only does it while towing. any questions ask away. thanks joe.
- Year: _1997_____
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
