I just rebuilt my 6.5 with a GEP knock off block. While it was still on the stand I pluged the cooler line ports and tried to prime it with a socket and drill. I didn't know I had to loop the cooler ports. While trying to prime it it just built pressure. When I stopped the drill I could hear oil squirting form somewhere in side the block. Instead of looping the ports I just installed it in the truck hooked up the oil lines and tried to prime it again. It built pressure again so I unhooked a cooler line and it was pressurized soooo I unhooked both lines and when I spin the drill I get oil out of both lines
. What the heck is going on? Did I screw something up when I tried to prime it with the ports plugged? I also blocked off the ports for the center mount turbo.
