luke22494
I am working on a 98 crew cab 2wd dually that had the pump pulled off due to “pump out of time but ran good”. I have it back running again but with the intake still off just to check everything out. My problem is that i have to jump the starter relay to make it start. With the key in acc position the gear indicator light comes on but goes out when i turn the key to the run position. The engine will not turn over by the key. I did notice that the wait to start light and the park indicator light will flash back and forth sometimes when i hold the key in the crank position. I have never seen this before. Im thinking ignition switch or nsbu switch. Thanks in advance.
