There seems to be alot of AC information here so I am hoping to get some help.
On my 1990 Chevy I noticed during the winter when the temperature got down to about 7 degrees there was something leaking from the back of the AC compressor and it appeared to be compressor oil. The system will not turn on unless I put a jumper on compressor, the system worked good before the cold weather and it was converted to 134 about 6 years ago. I am guessing the o-rings at the hose connection to the compressor are bad and need to be replaced. Can I disconnect the lines long enough to replace the o-rings then pull a vacuum on the system and add freon? Should I drain the oil in the compressor and add the specified amount back to the compressor if I do have to remove it to replace the o-rings? Thanks, BG
