Cumminalong
Doghouse Diesel Performance
Well I finally found the switch I want and the perfect spot for it.
Gonna do the install tommorrow..........and yes, there will be a DIY.
For those that are wondering, it's used to be able to manually lock the torque converter whenever you want. What it does is grounds the circuit to the TC which forces it to lock.
What this allows you to do is use the maximum amount of engine breaking while going down grades and it prevents the tranny front downshifting when you don't want it to. The main use I have for it is putting the truck on the dyno and making sure that it doesn't drop out of 3rd gear during the pull.
The switch is a normally off / momentary on, spring loaded push button.
I'm also going to rig a small LED up on the a-pillar that lights up when the button is activated.
Here's the switch and part numbers.....
Here's the spot it's going to go. The only part you will see is the round, silver base and the button itself. You won't see the lock ring or anything below it.....
All I have to do is lift a finger and push the button to lock the TC.....
