chrisk1500
- Messages
- 875
- Reaction score
- 0
Here is a quick 'how-to' on installing a manual glow plug override.
The purpose of the override is to jump the existing glow plug controller on the truck with a solenoid. You NEED to have self-limiting plugs in order to perform this mod safely. Self-limiting plugs include AC Delco 60Gs and Bosch Duraterms.
For this mod you will need the following:
16 gauge wire - 15 feet would be TONS of wire
8 gauge wire - 6 feet would be lots of wire
various wire connector ends - depending on what you use you will need a selection of eyelets, shovels, or spades.
Ford starter solenoid - I picked one up at a parts place for about $10. Tell them it is for a 79 F100.
Switch - I used a lighted bat handle SPST switch. YOU are free to use a push button style momentary switch if you are concerned about accidently leaving the switch turned on and running your batteries down.
Add a Fuse - I just jammed the 12v lead wire into the switched side of the radio fuse, but putting in an add a fuse would be the cleanest way to get power.
Step 1 - Find a place to mount your switch. On my 95, I pulled out the center bezel and put it there. Drill a hole for the switch. (PIC 1 - mounting, PIC 2 - Switch)
Step 2 - Run the 16 gauge wires. You will need 3 wires. One runs from a ground to the switch. One runs from a 12V source to the switch. One runs from the switch to the engine bay where it will be hooked up to the solenoid.
(PIC 3 - Wires hooked up to switch, PIC 4 - 12V source at the 'Radio' fuse)
Step 3 - Put the interior of the truck back together by reinstalling the bezel(s).
Step 4 - Find a place to mount the solenoid. I mounted mine on the firewall beside my alarm siren. (PIC 5 - Solenoid mounted on firewall)
I have exceeded my upload limit for this post (and I am not done the install anyways - it got too dark outside too quickly).
In my next post I will show you how to hook the solenoid up to the glow plug controller...
